- static vs dynamic stability
- math. cond. for static and dynamic
- Cm alpha diagram
- Cnb diagram
- Trim of horizontal tail vs. airspeed
- neutral point
- static margin
- horizontal tail volume dimensioning
- neutral point for yawing
- maneuver point and depending on altitude
- roll rate aileron defl
- yaw rate rudder defl
- poles of dyn stab
- explain motion of dutch roll
- phase shift of yaw and roll in the dutch roll
- profile of the wing during dutch roll
- phugoid and short period: whats constant, whats oscillating
- how can damping and frequency be influenced
- how does an instable spiral look
- how can you start the phygoid without the short period mode: thrust
- how can you start the dutch roll without changing your heading too much: Duplex rudder input
- why is there no restoring roll moment
- how can you lower the effect of the dutch roll: higher clb through dihedral angle
Best of luck to all of you!
